Add Machining FC options
OlofS
How do I add the 877-1 Machining FC options to my system? I managed to do it once, but I forgot how to do it
Thanks!
Thanks!
If you already have the option included in your key you can modify your system in System Builder and add the option in 'Modify Options'.If you have a new key with the option you will have to build a new system with that key string.0
Thanks a lot, I got i right now!
- 367 IRC5
- 858 RAPID Programming
