Add Machining FC options
How do I add the 877-1 Machining FC options to my system? I managed to do it once, but I forgot how to do it Confused
Thanks!
  • If you already have the option included in your key you can modify your system in System Builder and add the option in 'Modify Options'.
    If you have a new key with the option you will have to build a new system with that key string.
  • Thanks a lot, I got i right now!
