How to add event to menuitems in the command bar
Jing
in ScreenMaker
I'm trying to add click event to the menuitems added in the commandbar. But I cannot find how to do this.
Another question: is it possible to add sub menuitem to the menuitems added in the commandbar? and how?
Is anybody know?
Thanks very much!
H Jing,To define the list of actions associated with a menuitem, you need to1 - Select the menuitem instance inside the combo box which is in the top of the properties dialog2 - Select the "Events" tab3 - Double click in the Click event.In the current version, it is not possible to submenus.BR/CarlosCarlos Martinez
ABB0
- 367 IRC5
- 858 RAPID Programming
