fatal application error taf.exe
Our facility has many ABB robots and every now and then one will get a fatal application error.
Program: Taf.exe
Exception: 0X80000002
Address: 03586FCC
What can be done to prevent this?
Mel
  • What RobotWare version do you have? Can you provide a list of the options that your controller has installed? Is there a particular activity that causes this error? This is a generic error that can have numerous causes.
    Russell Drown
  • The robots have various RW versions ranging from 5.08_01.1009 to 5.10_0147. They have the following options:
    RW Control module key<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    RobotWare OS and English
    644-3 Spanish
    645-2 German
    709-x DeviceNet
    709-1 Master/Slave Single
    711-1 Prolibus DP Master/Slave
    602-1 Advanced Shape Tuning
    604-2 MultiMove Independent SingleProcess
    No manipulator with arc welding
    S No manipulator with spot welding
    No manipulator with dispense
    608-1 World Zones
    609-1 Fixed Position Events
    610-1 Independent Axis
    611-1 Path Recovery
    612-1 Path OfFset
    614-1 FTP-client
    616-1 PC Interlace
    617-1 FlexPendant Interlace
    620-1 File and Serial Channel Handling
    621-1 Logical Cross Connections
    623-1 Multitasking
    626-1 Advanced RAPID
    Thus far no particular set of circumstances has been identified to cause the problem
    Mel
  • The first step I would take would be to upgrade to the latest RobotWare version. As I mentioned, there have been a variety of fixes over time to address this sysmptom. Do you have any custom (3rd party) FlexPendant applications installed? Unhandled exceptions in user applications can also cause errors for Taf.exe.
    Russell Drown
