fatal application error taf.exe
What RobotWare version do you have? Can you provide a list of the options that your controller has installed? Is there a particular activity that causes this error? This is a generic error that can have numerous causes.Russell Drown0
The robots have various RW versions ranging from 5.08_01.1009 to 5.10_0147. They have the following options:
RW Control module key<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
RobotWare OS and English
644-3 Spanish
645-2 German
709-x DeviceNet
709-1 Master/Slave Single
711-1 Prolibus DP Master/Slave
602-1 Advanced Shape Tuning
604-2 MultiMove Independent SingleProcess
No manipulator with arc welding
S No manipulator with spot welding
No manipulator with dispense
608-1 World Zones
609-1 Fixed Position Events
610-1 Independent Axis
611-1 Path Recovery
612-1 Path OfFset
614-1 FTP-client
616-1 PC Interlace
617-1 FlexPendant Interlace
620-1 File and Serial Channel Handling
621-1 Logical Cross Connections
623-1 Multitasking
626-1 Advanced RAPID
Thus far no particular set of circumstances has been identified to cause the problem
Mel0 -
The first step I would take would be to upgrade to the latest RobotWare version. As I mentioned, there have been a variety of fixes over time to address this sysmptom. Do you have any custom (3rd party) FlexPendant applications installed? Unhandled exceptions in user applications can also cause errors for Taf.exe.
Russell Drown0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
