Error with using some FP(FlexPendant) toolbox item
Hi'
I have tried using the button icon from the FP toolbox, this results in an eeror at startup of the virtual FP. This gives an error message that reads: "Exception has been thrown by the target of an invocation"
It does this with many other items such as the checkbox, the graph, etc.
May you kindly assist on how I can overcome this!
Our deepest fear is not that we are inadequate, but powerful beyond measures!
  • Are you using the same version of RW, RS, and RAB for your system?
    Russell Drown
  • Yes I am using the same version RAB5.11.01 and RS5.11, on Visual Studio2008 IDE.
  • What about RobotWare version? Do you have the FlexPendant interface option in your system?
    Russell Drown
  • Yep, I have the FlexPendant option.
  • Which Robotware version does your system have?
    Carlos Martinez
    ABB
  • Hi'
    I am using the following versions:
    RW ver:   RW5.10_0147
    RAB ver:  5.11.01
    RS ver:    5.11
  • You have to use the same major RW version (5.11.xx) as RAB (5.11.xx) version, that is why you are seeing this problem.
    Russell Drown
  • Thanks  for your assistance, It is now working!
