Wobject with Conveyor Tracking
I'm working on a painting application with conveyor tracking, and i must use three different wobjects with the same mechanical unit. When i move the conveyor, one of them change its position (so it's ok), but the two other remain stopped.
It's a problem of my configuration or it's a RS limitation?
Thanks a lot for your attention.
Jordi
Hello Jordi,
Could you please make a Pack and Go of your station, and then make a .zip file of the Pack and go folder (your station name__pack&go)?
Please also make a .zip file of your controller ( C:Program FilesCommon FilesABB AutomationControlsyour versionRobotsyour controller name).
Finally send both files to the following e-mail adress : support_software.serop@se.abb.com and I will try to help you.
Thomas Andersson
Support Engineer
ABB Automation Technologies
ATMA/RO/AIS0 -
Hi Thomas,
Ok, i'll send you today. Thank you in advance for your help.
Jordi.
I don't know what to say..0 -
Do you use some sort of Paint powerpac on RobotStudio for creating paint paths?
Regards,
Jan-Jaap0 -
Hello Jan-jaap,
I've paint powerPac v.2.0, but i use standard options to create my paths. I use powerpac when i must put into the painting events, or for moving the conveyor the conveyor on teach mode, because it's faster.
Tot ziens
Jordi
- 367 IRC5
- 858 RAPID Programming
