Error with using some FP(FlexPendant) toolbox item
Dezino
Hi'
I have tried using the button icon from the FP toolbox, this results in an eeror at startup of the virtual FP. This gives an error message that reads: "Exception has been thrown by the target of an invocation"
It does this with many other items such as the checkbox, the graph, etc.
May you kindly assist on how I can overcome this!
Our deepest fear is not that we are inadequate, but powerful beyond measures!
Are you using the same version of RW, RS, and RAB for your system?Russell Drown0
Yes I am using the same version RAB5.11.01 and RS5.11, on Visual Studio2008 IDE.Our deepest fear is not that we are inadequate, but powerful beyond measures!0
What about RobotWare version? Do you have the FlexPendant interface option in your system?Russell Drown0
Yep, I have the FlexPendant option.Our deepest fear is not that we are inadequate, but powerful beyond measures!0 -
Which Robotware version does your system have?
Carlos Martinez
Hi'I am using the following versions:RW ver: RW5.10_0147RAB ver: 5.11.01RS ver: 5.11Our deepest fear is not that we are inadequate, but powerful beyond measures!0
You have to use the same major RW version (5.11.xx) as RAB (5.11.xx) version, that is why you are seeing this problem.Russell Drown0
Thanks for your assistance, It is now working!Our deepest fear is not that we are inadequate, but powerful beyond measures!0
