Wobject with Conveyor Tracking
I'm working on a painting application with conveyor tracking, and i must use three different wobjects with the same mechanical unit. When i move the conveyor, one of them change its position (so it's ok), but the two other remain stopped.
It's a problem of my configuration or it's a RS limitation?
Thanks a lot for your attention.
Jordi
I don't know what to say..
  • Hello Jordi,
    Could you please make a Pack and Go of your station, and then make a .zip file of the Pack and go folder (your station name__pack&go)?
    Please also make a .zip file of your controller ( C:Program FilesCommon FilesABB AutomationControlsyour versionRobotsyour controller name).
    Finally send both files to the following e-mail adress : support_software.serop@se.abb.com and I will try to help you. image
    Thomas Andersson
    Support Engineer
    ABB Automation Technologies
    ATMA/RO/AIS
  • Hi Thomas,
    Ok, i'll send you today. Thank you in advance for your help.
    Jordi.image
  • Hello,
    Do you use some sort of Paint powerpac on RobotStudio for creating paint paths?
    :) Regards,
    Jan-Jaap
  • Hello Jan-jaap,
    I've paint powerPac v.2.0, but i use standard options to create my paths. I use powerpac when i must put into the painting events, or for moving the conveyor the conveyor on teach mode, because it's faster.
    Tot ziensimage
    Jordi
