Problems with RW 4.0.111 & 112
We have noticed problems with RobotStudio and the RobotWare versions RW 4.0.111 and RW 4.0.112, please aviod to use these versions.
4.0.110 and 4.0.113 works OK.
Best regards
/Ulrika Mor?n
Ulrika Mor?n38421,6969444444
  • As I know, RS3.1 supports only RW 4.0 100.
    What should I install in order to use RW 4.0.110 and 4.0.113 in RS3.1?
    Sungwoo Jung
  • You just install the RobotWare that you want from the RobotWare CD.
This discussion has been closed.
