Newbie Question
Good evening. I'm about to use robotstudio for the first time, in a work to the university. I would like to know what are the programming languages that can be used. Thanks
Drake2009-03-26 03:11:44
  • Hi,
         I suggest you to start with the help videos available with the basic installed RS and then try the same by your self using the help file. You can also refer to the demo cells available. You cann always post querry for any help.
    regards,
    Nikhil
    Regards,
    Nikhil
