Connect / Disconnect from/to robot [WebWare SDK]
Hello there. I have a question according to general communication matters.
Robots used: S4, S4C+, IRC5 with Ethernet Option enabled (robots are pingable)
Dev: VB6 with SDK3.2 and Interlink 3 installed
Dest.: PC with VB6-runtimes and installation of our app + Interlink 4
I am planning to use the app on more than one machines (PC) at the same time.
In the manner of communication, you generaly do this:
1) set up the communication
2) connect
3) do some things
4) disconnect
Does Webware support such things? Maybe that's a stupid question, but I've been searching for a long time in the documentation and I did not find what I was searching for.
Could someone provide some code-fragments?
thx in advance
01000111
The common behaviour is having the SDK application running on the a machine where Interlink is always connected to the Robot.
However if you have a need to run multiple SDK applications on seperate machine, communicating with the same robot, you should disconnect the Interlink session for a given robot.
Basically, it is recommended that only one Interlink session at a time should be used for an individual S4 robot.
AndersD38400,3798726852
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0 -
You said, only one app should be connected. Is there a possibility to check, if another InterLink is connected to the robot?
If not, i would have to place an "authorisation"-server, which synchronizes the connections.
The main purpose of our app is to periodicaly backup files from the robot.
I do the following @ the moment
' author: Mathias Richter
' date: 2005-02-16
' function: lists all available Interlink ALIASes
' in debug-window
Dim i_Counter As Integer
Dim i_ErrorCodeABB As Integer
Debug.Print "Displaying all Alias in INTERLINK (" & ABBHelper.AliasListCount & ")"
For i_Counter = 0 To ABBHelper.AliasListCount - 1
Debug.Print "Alias[" & i_Counter & "]" & ABBHelper.AliasList(i_Counter)
Next i_Counter
' date: 2005-02-16
' function: connect to a ALIAS (ABB-Robot)
' checks Interlink for valid ALIAS
' returns connectionstate in debug-window
' in: index
' remarks: index directly addresses the ALIAS
' see: ListAllAlias
' check aliasIndex <=?=> aliasName wanted
Debug.Print "connecting to ALIAS(0)"
If 0 > ABBHelper.AliasListCount - 1 Then
MsgBox "Alias nicht in Liste!"
End If
ABBHelper.Robot = ABBHelper.AliasList(0)
Select Case ABBHelper.InterfaceState
Case ABB_Connected: Debug.Print "Connection established"
Case ABB_Disconnected: Debug.Print "Connection failed: disconnected"
Case ABB_Halted: Debug.Print "Connection halted by Interlink"
Case ABB_NoAliasInList: Debug.Print "Alias not found"
Case ABB_Simulated: Debug.Print "Connection simulated"
End Select
' date: 2005-02-16
' function: test
Debug.Print "Testing environment"
Debug.Print "done testing"
' date: 2005-02-16
' function: disconnect from ALIAS (ABB-Robot)
Debug.Print "disconnecting from ALIAS('" & ABBHelper.Robot & "')"
If (ABBHelper.InterfaceState = ABB_Disconnected) Or _
(ABBHelper.InterfaceState = ABB_NoAliasInList) Then
MsgBox "Error: no connection"
End If
ABBHelper.Robot = ""
Case ABB_Connected: Debug.Print "Connection stil alive"
Case ABB_Disconnected: Debug.Print "Connection disconnected"
Case ABB_NoAliasInList: Debug.Print "Connection terminated"
Case ABB_Simulated: Debug.Print "Connection stil simulated"
End SelectBy dooing so, is the communication to the robot closed? Or do I have to do more? If so, could you give me hints/code-fragments?
010001110 -
How do you actually check if the robot is in stopped state and not in start state? Need to check this before I allow programchange.0
You can use the events of the Helper control to check the state or the robot and program states. Please see StatusChanged Event in the SDK manual for more details where the different state definitions are defined.
Anders Dannberg
Support Engineer0 -
[QUOTE=Svempa62]How do you actually check if the robot is in stopped state and not in start state? Need to check this before I allow programchange.[/QUOTE]
Well, I changed my strategy and dynamicaly add / remove the Interlink alias, some example is available from AndersD I think in this forum.
But in general the Interface-property is the right signal to trigger the state of the robot (if InterLink can connect to the robot).
010001110
- 398 UpFeed
- 300 PowerPacs
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
