Linear Move menu not enabled
frangou
Good morning from France,
The menu to control the robot axis by axis is available. However, the menu to control the robot in linear is always gray (see picture below). If I add a third robot, there is no improvement. Do you know the possible causes?
This screen is on the french version on Robot Sudio.
Best regards.
Frangou (France)
Have you set up a controller for the system
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
HiI can see that you haven't started any virtual controllers (lower right corner of the picture, status bar)Per Svensson
Consat Engineering0 -
Thanks you all.I've not assigned a controller to each robot.It's OK now.Frangou (France)0
- 346 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
