Group Input negative values ?
lakris
As I understand, 'Group inputs' are only interpreted as positive integer values.
Does anybody know if there is a conversion function so that I can convert to integer with sign.
I send values from a Siemens PLC via Profibus/Devicenet gateway and have defined them as an 16 bit Group input.
I send them as 16 bit integers with sign [-32768;32767] as twos complement
Do I have to write a conversion function myself or is there a smarter way?
Thank You,
lakris
I have use following function I made. Remember to select correct notation you need and change it inside my function.I guess you can also try to change your group input to analog input and use it directly. I think you can search this forum to find thread about it.FUNC num GetSIntGi(
VAR signalgi giRead)! Function: GetSIntGi 4.9.2006
! Get signed integer from 16bit (bits 0-15) group input.
! Bit 15 is the sign bit, so values equal or bigger than 32768 are negatives
! and needed to be converted to corresponding negative decimal value
VAR num notation;
VAR num value;! There are 2 interpretations for negative binary numbers.
! Select which notation to use for negative binary numbers.
! notation:=1 -- sign magnitude notation - Returned values are between -32767 to 32767
! notation:=2 -- two's complement notation - Returned values are between -32768 to 32767
notation:=2;! Get the integer value from group input (from PLC)
value:=0;
value:=GInput(giRead);
! Convert unsignad integer to the signed integer according the notation used by PLC
IF notation=1 THEN
! Sign magnitude notation
! bit15 is sign bit, otherwise same as positive binary numbers
IF value>32767 THEN
value:=32768-value;
ENDIF
ELSEIF notation=2 THEN
! Two's complement notation
! bit15 is sign bit, negative values are inverted and added 1
IF value>32767 THEN
value:=value-65536;
ENDIF
ELSE
! Notation not set.
! Return value as it is read.
ENDIF
RETURN value;
ENDFUNCRegards,Mika0 -
you didnA't need a function.
Declare a analog input like this
-Name "aiShiftingX" -SignalType "AI" -Unit "PB_KARTE" -UnitMap "80-95"
-MaxPhys 3276.7 -MaxBitVal 32767 -MinPhys -3276.7 -MinBitVal -32767
and you can use the value directly in your program. The range is in this configuration from -3276.7 up to 3276.7.
It is possible to declare an analog input instead a groupinput.
BR
Thilbi
Thank You very much.
I have defined my inputs as analog inputs instead of group inputs, and it works.
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
