IRB4600 45-205
ziga
I have downloaded IRB4600 45-205 rslib file from http://inside.abb.com/product/seitp327/8c73a1fa083fb25fc12574dc0045a9af.aspx?productLanguage=si&country=00&tabKey=7
but it is actually IRB4600 60-205 version. Can you please update the file.
BR/Ziga
Hello Ziga,As the reach of the robot is same in both versions, so the same RSLIB file is provided for both of them.If you still wish to take the exact RSLIB file then you just update your Librarytypes.xml file in"C:Program FilesABB Industrial ITRobotics ITRobotStudio 5.11ABB LibraryRobots"folder. It'll still bring the same model but will make a system for 45Kg version.Regards,
Saurabh Vashist0 -
Thanks for the answer, I'll follow your advice.BR/Ziga0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
