RS232
Klaus
Is it possible to test a program where you get data from a rs232 connection in WINtpu.
If i define a com1 on my TP in RS is it then possible to test a program, if i connect a device to com1 on my PC and then use the program on a robot
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hello Klaus,
What you describe is not possible to test with our software.
Best regards
/Ulrika Mor?n
Support Engineer
