Attach signal to a tool
Hello everyone, i started to work on robotstudio since one week an I want to create a little program with an IRB 140 ,a custom gripper and a cube which is moved.
I created a tool with 2 positions GripOpen and GripClose, now I want to attach these positions to an output signal called 'GripOpen'.
How can I do that ? Smile
Thanks in advance !
  • Klaus
    Klaus ✭✭
    If you define your gripper as a mecanism you can add an event that runs it to a pose when the signal change state.
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • hi,
    You can use Event manager to link 2 signal
  • Hi, thank you for your answers Big smile , now i've another issue, I created a path with 4 targets, i've followed instructions to place the tool in the good position but i've two problems:
    - I can't compile the program, the following error appear :
    "IRB140_5kg_0: Could not set program pointer to entrypoint for task T_ROB1 Please check your program for errors"
    - Can I control station signals with RAPID program, because i've already tried SETDO and SET/RESET command and it doesn't work
    Thanks in advance !
    MrStudent2009-04-27 15:27:05
  • Klaus
    Klaus ✭✭
    IO used in rapid program has to be in the robotsystem. I don't think you can use station signals. They are not a part of the robotsystem
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
