Creating add-in using Visual Studio
For example, if I would like to test the Logger-example in the API documentation - is this what the complete Visual Studio C#-code should look like?:
__________________________________________________using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using ABB.Robotics.Math;
using ABB.Robotics.RobotStudio;
using ABB.Robotics.RobotStudio.Environment;
using ABB.Robotics.RobotStudio.Stations;
using ABB.Robotics.RobotStudio.Stations.Forms;namespace Addin1
public class Class1
{public static void AddinMain()
Project.UndoContext.BeginUndoStep("Logger");
try
// How to add categories to the Logger!
// Add two categories.
Logger.CategoryCaptions.Add("MyKey", "My Category");
Logger.CategoryCaptions.Add("AnotherKey", "Another Category");// Print a message in different categories.
Logger.AddMessage(new LogMessage("This is just a test
message!", "MyKey"));
message!", "AnotherKey"));
catch (Exception e)
Project.UndoContext.CancelUndoStep(CancelUndoStepType.Rollback);
throw e;
finally
Project.UndoContext.EndUndoStep();
}__________________________________________________0 -
When i Debug the program above I get the following message from Visual Studio:
"A project with an Output Type of Class Library cannot be started directly...."Should this be the case?EDIT:I found the following:danwa2009-05-03 15:56:14
http://msdn.microsoft.com/en-us/library/68c8335t(VS.80).aspx
This states that Start external program is not available in Visual Studio Express. Is this function necessary to be able to build applications for RobotStudio?0 -
Hello danwa,
I found this which explains how to debug a DLL in Visual Studio Express. In short, your MyProjectName.csproj.user should look something like this:
[code]<Project xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<StartAction>Program</StartAction>
<StartProgram>C:Program FilesABB Industrial ITRobotics ITRobotStudio 5.12BinRobotStudio.exe</StartProgram>
</PropertyGroup>
</Project>
[/code]
Your code looks correct. Note that the UndoContext statements aren't strictly necessary in this case since you only call logger methods. Only methods that somehow modify the station data are undoable.
regards,
Johannes
Johannes Weiman
ABB Robotics0
