seeking help about voltage signal input
Hi.You need an analog input board on the robots devicenet. You can use ABB or other products. Are the signal voltage or miliambre_I have good experience with beckhoof. They are not as expensive as ABB and is working very well.BR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi Klaus,
The signal is voltage, 21v for instance.
I know that there is an unit called DSQC 355A for analog I/O. If the signal is 21v, how can i let robot controller know the value of "21" using DSQC 355A? How to use this unit?
On the unit of DSQC 355A, there is an "X8" pin for analog input. the description in manual is // analog input 1, -10v/+10v//, does it mean it can receive and read the value of voltage ranging from -10v to +10v continuouslly?Thanks a lot.
steven
Hi Steven.To use over 10 volt input you need to find another board than ABB. It's easy to use other products as long they can bee connected to the device net that is standard on the IRC 5.lok at http://www.beckhoff.com/ or contact your local dealer og beckhoffBR KlausBest Regards
Klaus Soenderhegn
Hi Klaus,
I have read the information in website of beckhoff. Can you give me a specific example about using devicenet and product of beckhoff to deal with analog input, what kind of device is needed and how to connect them for instance? I have never used this kind of products before.
Thanks a lot.
steven
Hi steven.Send me an email at kls@proinvent.dk and i can give you a EIO.cfg with settings ogf beckhoff AOBR. KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 367 IRC5
- 858 RAPID Programming
