err. 33417
have you ever faced with err. 33417?
we checked all parts, no clue...
could be smd?
s4c+, irb2400
  • Hi
    33417: Transmission error mea
    Error in measurement system %d
    at connector board %d when test-
    ing seriel link in normal mode.
    Check:
    - Check configuration of
    MEASUREMENT_CHANNEL
    - Check seriel link
    - Check/Replace measurement
    board(s)
    - Check/Replace Axis Computer
    board
    Regards
    Knud Erik Lindberg
    Danrobotics
  • thx for the quick reply.
    we changed smb and smb connection cable..
    nothing has changed...
    axis board?
  • Try to change axiscomputer
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Hello,
    In general, the error occurs when those parts are broken. (AXC, SMB, SMB cable)
    If you have already replaced all parts, and the robot is stil in faulty,
    then there must be  a sort of disturbances between AXC and SMB.
    The last thing to do is to check all connections.
    BR,
