err. 33417
have you ever faced with err. 33417?
we checked all parts, no clue...
could be smd?
s4c+, irb2400
Hi33417: Transmission error mea
Error in measurement system %d
at connector board %d when test-
ing seriel link in normal mode.
Check:
- Check configuration of
MEASUREMENT_CHANNEL
- Check seriel link
- Check/Replace measurement
board(s)
- Check/Replace Axis Computer
boardRegards
Knud Erik Lindberg
Jorgensen Engineering0 -
thx for the quick reply.we changed smb and smb connection cable..nothing has changed...axis board?0
Try to change axiscomputer
Regards
Knud Erik Lindberg
In general, the error occurs when those parts are broken. (AXC, SMB, SMB cable)
If you have already replaced all parts, and the robot is stil in faulty,then there must be a sort of disturbances between AXC and SMB.The last thing to do is to check all connections.BR,0
- 365 IRC5
- 84 OmniCore
