taf.exe error
alan
Dear all,
I got a problem when developing a FP RAB application.(just read a config file and set a signal).the application noramly is ok.
but when I press control panel >configration(in Real GTPU),I choose Topic and I can't find IO item and also there is no info. about IO, that means I can't define any IO signal. if press close in commandbar, no response. if press several times continues or use 'X',sometimes GTUP will display a error like below
TAF.exe error
at system.io_error.winIOError()
at system.io.fileStream.writeCore()
at system.io.fileStream.flushwrite()
at System.IO.filestream.flush()
at system.IO.fileStream.dispose().
I use RAB5.10 and robotware5.11.02. in RAB application. I have dispose the signal that I have used.
same application in vitual controller(RW5.11.02). no problem..
some code:
void PrgLoad(object sender, ABB.Robotics.Tps.Windows.Forms.MessageBoxEventArgs e)
Signal progType = _controller.IOSystem.GetSignal("goDataSetNo");
progType.Value= Convert.ToInt32 (progNum);
progType.Dispose();
progType.Dispose();
public void CheckInfo()
signal1 = _controller.IOSystem.GetSignal(HomeSignal);
if (signal1 == null)
GTPUMessageBox.Show(this, null, "Please Set Key signal");
InHome = 0;
else
digitalSig = (DigitalSignal)signal1;
digitalSig.Changed += new SignalChangedEventHandler(digitalSig_change);
public void digitalSig_change(object sender,EventArgs e)
this.Invoke(new ABB.Robotics.Controllers.IOSystemDomain.SignalChangedEventHandler(this.UpdateUI), new Object[] { sender, e });
private void UpdateUI(object sender, SignalChangedEventArgs e)
SignalState state = e.NewSignalState;
float val = state.Value;
if (val==1)
InHome = 1;
if (val==1)
InHome = 1;
else{
InHome = 0;
else{
InHome = 0;
protected override void Dispose(bool disposing)
if (!IsDisposed)
try
if (disposing)
if (!IsDisposed)
try
if (disposing)
_controller.Dispose();
digitalSig.Changed -= new SignalChangedEventHandler(digitalSig_change);
signal1.Dispose();
finally
base.Dispose(disposing);
pls give sme ome suggestion? thanks a lot.
BR//alan
Hi Alan,I was confused:- What is causing the error: your application or the ControlPanel View?- You mention that it works OK, but then it does not.In the Dispose method, try to dispose the controller instance at the end.Carlos Martinez
hello,sorry my description confused u.I have try to open another windows like INPUT and output or others buttion in real GTPU main interface, it' no effection for the RAB application. just when I press control panel-> configration and system will display the error message.I can't see IO configration in real GTPU.control panel-> configration view will lead to the problemBR//alan0
That is strange ..- Have you tried to create a new system?- Can you share a back-up in order to reproduce the problem?BRCarlos Martinez
now, it's done. problem is memory leak, thanks all0
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
