Populate and select file from listview
Hi I'm using RAB and Robatware 5.12 on VS 2008
I want the user to look through a listview of available files and folders for a module and then to load that chosen module into the controller for use with my program.
I've added the following to the VB code
Friend
WithEvents aFileSystem As FileSystemDomain.FileSystem
Me.aFileSystem = Me.aController.FileSystem
I'm trying to replicate the explorer window as i have constructed a listview with 2 columns with 'name' and 'type' but I'm not sure how to populate the listview with the files and show the folder or file icon next to them.  I also need to navigate the directory tree.  I'm pretty sure the GTPUFileDialog will be used as well but just not sure how?
Any examples would be greatly appreciated...
Regards,
bigM
  • You can try GetFilesAndDirectories(searchpattern) which will give return a list of all files and folders that meet the search pattern, but it would be far simpler just to use the GTPUOpenFileDialog with filters for *.mod or *.sys. This is well-documented in the RAB User's Guide.
    Russell Drown
  • Hi Russ,
    I've dragged the GTPUOpenFileDialog to my TabControl but I've add the textbox, listview etc manually.  The RAB example looks like it generates the whole view.
    I'm totally lost here. I see it in the components pane but there are so little properties for it.
    Any steps to get me in the right direction?
  • Got it!,
    Its just like a message box, just display it with    .showme()
