MoveL instruction
     I have a strange problem.I am working with a Flex Picker IRB 360.
I have a program in C# sends the data to Robot Contorller through TCP/IP communication.The received data is used to move the robot to target points.Instead of the Robot moving to Target positions it always move to X=0 and Y=0 position.
below is the code
MODULE TCPIP
< ="-" ="text/; =utf-8">< name="ProgId" ="Word.">< name="Generator" ="Microsoft Word 11">< name="Originator" ="Microsoft Word 11">
VAR SocketDev
Socket_Server
VAR SocketDev
Socket_Client
VAR string ReceiveMessage;
VAR string ControllerIP;
VAR num ReceivedOption;
VAR bool Dummy;
VAR robtarget
r1
VAR String sP1x;
VAR string sP1y;
VAR num pr1x;
VAR num pr1y;
VAR num r1x;
VAR num r1y;
PROC MAIN()
SocketCreate Socket_Server;
SocketBind Socket_Server,"172.29.74.1",1025;
SocketListen Socket_Server;
SocketAccept Socket_Server,Socket_Client;
SocketReceive Socket_Client Str:=ReceiveMessageTime:=WAIT_MAX ;
TPWrite "Message
received "
+ReceiveMessage;
Dummy:=StrToVal(ReceiveMessage,ReceivedOption);
SocketSend Socket_Client Str:="Message received";
sP1x:="P1x";
pr1x:=ReceiveSend(sp1x);
r1x:=pr1x;
sP1y:="P1y";
pr1y:=ReceiveSend(sp1y);
r1y:=pr1y;
r1:=[[r1x,r1y,Pz],[0,1,0,0],[0,1,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];
MoveJ r1,V500,fine,tool2;
SocketClose Socket_Server;
stop;
FUNC num ReceiveSend(var string Point
VAR string Receive;
VAR num Position;
SocketReceive socket_Client Str:=Receive;
TPWrite""+Receive;
SocketSend socket_Client Str:=Point;
Dummy:=StrToVal(Receive,Position);
Return Position;
ENDFUNC
ENDMODULE
Incase of further calirifications please let me know.
Cheers
Ravi
  • Jorge
    Jorge ✭✭
    Try to change the vars to persistence insted var
    /Jorge
    Jorge Turiel
  • sturner
    sturner ✭✭
    robtargets are normally defined with the type 'Constant'
    leaving them as Var will set them to zero when program pointer is reset
