How can I use GU( buttom ) for set or reset Input
Mr.Robot
in ScreenMaker
I would like to use GU( buttom ) for set or reset Input .
How can i do it?
Please guide me some how.
Thank you so much.
Best Regards,
Mr.Robot
Hello,If I understand your request correctly, you want to use the GUI (Button) to set/reset and Input. There are many ways of doing this, The simplest is to start with the example that is provided with the ScreenMaker CTP and see how the buttons are set up to the I/O signals.If there is something else that you are trying to do, please let me know.Kind Regards,Steve0
