Position Robor World & Targets with Wobj
JK Hwang
hello,
Whenever changing 'Position Robor World', targets move.
Is there any way Not to move the targets?
Currently, I am subtracting the offset values in wobj for compensation.
In 'Position Robor World' dialog box, check box, 'Keep WObjs position' exists.
But it seems not working. No difference at all.
JK Hwang38428,6525
The checkbox "Keep Wobjs Position" doesn't work on wobj0 so if you have your target in that workobject they will not stay in position.
Per Svensson
Company Specialist
Workaround:
Create a dummy workobject located at the same position as wobj0.
Drag&drop all targets in wobj0 to the dummy without repositioning the targets.
Then change the robots world with "Keep wobjs position" checked
Now Drag&drop the target from the dummy back to wobj0, again without repositioning them...
regards
Christian0
