RS5.12 ConveyorTracking Setup menu
Hey??s
Could you pls help me to find the ConveyorTracking 'setup' menu in RS 5.12?
Confused
  • Hello,
        What do you mean with "setup"? If you mean Conv. Track. Calibration, you can tap Control Panel => Configuration => Fieldbus Command => Qtrack1. Count per Meter and Base Frame Calibration are the most important things in onsite (online) programming. If you want to simulate (offline programming), please read RS Help => search : conveyor tracking. In the right side (offline menu) you will find Encoder Unit.
    BR,
    Dhyan
    Indonesia
  • Sorry ,I means this menu
  • Here you go:
    Regards
    Knud Erik Lindberg
    Jorgensen Engineering
  • [QUOTE=Knud E Lindberg]Here you go:
    [/QUOTE]
    Hi, Maybe i mislead you;in RS 5.11.02 the setup menu is below, where is it in RS 5.12?
    lister2009-06-05 06:53:17
  • Her it is
    Regards
    Knud Erik Lindberg
