RS5.12 ConveyorTracking Setup menu
lister
Hey??s
Could you pls help me to find the ConveyorTracking 'setup' menu in RS 5.12?
What do you mean with "setup"? If you mean Conv. Track. Calibration, you can tap Control Panel => Configuration => Fieldbus Command => Qtrack1. Count per Meter and Base Frame Calibration are the most important things in onsite (online) programming. If you want to simulate (offline programming), please read RS Help => search : conveyor tracking. In the right side (offline menu) you will find Encoder Unit.
BR,
Dhyan
Indonesia
fear of GOD is the beginning of wisdom0 -
Sorry ,I means this menu
Here you go:
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
[QUOTE=Knud E Lindberg]Here you go:[/QUOTE]
Hi, Maybe i mislead you;in RS 5.11.02 the setup menu is below, where is it in RS 5.12?lister2009-06-05 06:53:17
Her it is
Regards
Knud Erik Lindberg
- 364 IRC5
- 83 OmniCore
