FTP Server Questions
rex2802
Note sure if this is the place to ask, but here goes.
I am using the FTP server built into the IRC5 controller. I can FTP file from the DOS command box to the IRC5 HardDrive but ONLY to the Directory named "HOME"
I have tried different syntax DIR callouts but haven't been able get the files to a folder I have created on the IRC5.
I am logged into the IRC5 as an Administrator
Thanks,
Jack
Hi.As i remember you can only acces home with FTP. use filebrowser in RS.Don't know if PC interface option has to do with it?BR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Thanks Klaus. I did find that I can only GET/PUT files into the HOME directory. Evenig trying the "dir" syntax doesn't change the outcome.Jack0
