FTP Server Questions
Note sure if this is the place to ask, but here goes.
I am using the FTP server built into the IRC5 controller. I can FTP file from the DOS command box to the IRC5 HardDrive but ONLY to the Directory named "HOME"
I have tried different syntax  DIR callouts but haven't been able get the files to a folder I have created on the IRC5.
I am logged into the IRC5 as an Administrator
Thanks,
Jack
  • Klaus
    Klaus ✭✭
    Hi.
    As i remember you can only acces home with FTP. use filebrowser in RS.
    Don't know if PC interface option has to do with it?
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Thanks Klaus. I did find that I can only GET/PUT files into the HOME directory. Evenig trying the "dir" syntax doesn't change the outcome.
    Jack
