Mirror of cutouts on carpet [KMT PowerPac]
Hello. I am programming a floorcarpet on KMT Cuttingbox. Is there any possibility to mirror the  cutouts?
  • Hello Peter! Use the car-zero-frame as a mirrorplane and then just mirror all cutouts. Normaly you can also re-use middle and rear sections of the outer contour as well
    Thumbs Up
    #1 Mark you floor carpet, right click and select "set as USC" or "als BKS setzen".
    #2 Select your path and right click choose path/mirror
    #3 select UCS / BKS as "reference" and "flip axis Y"
    Good luck!Smile
    Best regards
    Conny
  • by the way, see Chapter 3.8b about mirror-function in your training documentation Smile
