SmartComponents developed in 5.61 will not be visible in 5.15
Options
I have developed a Gripper Smart component in 5.61 along with a code behind.
If I try to open that in 5.15 its not visible.
in 5.14 it shows error.
Please provide any solution .
Thanks in advance and Regards
Rajesh GK
This is almost the case when it comes to software. So you need to develop it on 5.15 and then it will hopefully work in 5.15
But don't expect 5.61 would work in 5.15 because that will stop development progress.
Per Svensson
Consat Engineering0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
