Seeing the cross connection of the controller through RobotStudio Add-In
Is it possible to visualize cross connection configuration of the controller? I would want to see the state after running respective Add-In.
I have tried to make an Add-In in C#, but it is only possible to see the controller’s signals state without Operators of the cross connection. I can make the .cfg file and then base the visualization on this. However I would like to instantly download the cross connection state by running Add-In. Additionally, it would be great to have the opportunity to see more than one cross connection.
Thank you in advance.
- 858 RAPID Programming
