RS 6.04 and Hose Simulator
Is the Hose Simulator working in RS 6.04? Following the installation instructions, it says to extract in the "C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.04\Addins", but there is no Addins folder, and if I create it and extract there, RS 6.04 32bit version doesn't recognize the Hose Simulator.
Thanks for your time,
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Maybe if you find where other Add-ins are and put Hose Simulator there its gonna work.
/Adnan
the addins folder is located under the bin directory ie. C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.04\Bin - and seems only present in the 32 bit folder...
Regards, LarsLars Glud
Danrob A/S1 -
RobotStudio 6.05 will include true physics simulation including cables/hoses!
Johannes Weiman
Software Engineer
RobotStudio Team, ABB Robotics2 -
Is there a way to shut physics off besides making everything inactive?0
