Future of Screenmaker
wbijlsma
in ScreenMaker
I was wondering what the future of Screenmaker is.
Up to RS6.04, Screenmaker is still only available in 32 bit version, but now there's a notification that 32-bit support will end at RS6.06.
Is there a plan to continue with Screenmaker, or will there be a new platform at v6.06?
One of the reasons I'm asking, is that we've developed a standardized, multi-page HMI layout on Screenmaker. It has grown over the years, to where now it is displaying so much information, that it is getting quite laggy.
We have been considering starting over, but if Screenmaker isn't going to be around by middle of next year, then I'd rather just continue on for now, and not "redo" everything, twice..
Thanks for any insight.
Hello!
Any news at this topic?
I hope they ditch it soon and quit selling it, or make it work better. It has been nothing but problems for me.
One particularly bad problem I had was that images were encoded into the resource file... so I had a 200kB bitmap added in, and it serialized it and put it in the resource file of every screen. That made the memory footprint almost 5MB, which ate up the pendant's memory. It would start sometimes, other times would crash with a 'not found' dll error. It got worse when trying to troubleshoot it, because even after a rebuild with ALL images deleted, the resource files still contained a copy of the bitmap! I had to manually clean out the temp folder so it would rebuild the resource files... then I used PNGs and got rid of all unnecessary images.
Just saying, my HMI is still pretty sluggish, but be sure you use really light weight images and clean out that tmp folder before each build.0 -
RobotStudio 6.06 will support 32-bit (with some limitations) and ScreenMaker.Johannes Weiman
Software Engineer
I find Screenmaker very useful to create bespoke HMI Screens for the Pendant, however it takes forever to troubleshoot and re-define I/O. I hope the ability to create user screens is not lost in future releases. Anything that replaces Screenmaker must be simple to use and Bullet proof.... Please!0
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
