how to download a gripper cadd file online to robotstudio
hii everyone, i am an mtech student and doing my project on abbirb1200 robot. i need to attach gripper to the robot which not available in tool library of robotstudio. what am i suppose to do
thankfully
roshni
thankfully
roshni
Hi there,
Well, if you need a customized gripper/tool there are some few steps that can be followed:
1) Draw your gripper, download irb1200 cad for measures, then using a cad editor draw it and export it to a supported extension, for .sat
2) Upload your geometry (filename.sat) to RobotStudio using using import geometry function, under Modeling or Home tabs.
3) Use create tool function ( under Modeling tab )
4) On the Layout tree menu right click on the created tool and select attach to... option and select IRB1200....
Can also drag and drop the tool u have created over IRB1200... robot in the layout.
Which version of RobotStudio are you using ?
All the BEST,0
