Multimove without ethernet card
hi all
This is my situation, we have in the university two robots IRB-140 each one with one controller irc5 single cabinet and I want to do multimove but we don't have a drive module so I have disconnected signal safety cable and ethernet cable from one controller and have connected them to the second controller(this controller have the application multimove cordinate) after that I can activate the robot. the problem is that the second controller doesn't have ethernet card so there is only one port(AXC) to connect de drive module, I saw in this page http://developercenter.robotstudio.com/BlobProxy/manuals/SysParametersTechRefManual/doc7.html this "If MultiMove is used, AXC is connected to a switch that connects to all the axis computers." so I have connected a switch to AXC port and ethernet cables from drive modules to the switch after I start the controller this releases the event message 39525 Drive Module startup error. I don't know how to fix it, please someone help me.
- 38 AppStudio
