Cyclic Brake Check
JOEHOE
How many log files does it create in the temp directory on a real controller?
Can this fill up your harddisk if you do a check every 90 hours?
I do this check on a old controller with a flash card of 250mb... with RW 5.15.13
Is there any possibility to disable the logging in the temp directory?
Regards,
JOEHOE
Regards,
JOEHOE
