Thoughts about the HTTP headers
Hi, I have been using the new RW6 REST API for a while now and I think it works really well.
I was thinking that adding "Access-Control-Allow-Origin: *" to the response headers would improve the API since it would allow for webpages to fetch data from the robot controller without needing to be served from it. Furthermore; although the character encoding is specified in the XML document, this information is not present in the JSON response and could be specified in the HTTP headers as well.
Cheers!
Cheers!
Facing the same issue.
Yep, that would pave the way for modern React JS apps.
Creating a backend server in python or .Net backend to interface with the robot controller's REST interface feels really redundant, since the front-end can just as well consume the REST API.
Found the config file of the
RESTserver running on the robot ( located:/hd0a/05-102162/Products/RobotWare_6.05.0129/system/appweb.conf). The server software used isEmbedThis.
The conf file suggest that authentication is configurable / could be turned off.
That said, I ran into changing the file; seems additional permission is required and the usual ABB pwd's didnt pan out here.<Route ^/poll> AuthRealm "validusers@robapi.abb" AuthType digest AuthDigestQop auth WebSocketsProtocol robapi2_subscription AddFilter webSocketFilter SetHandler wsSubscription RequestTimeout 72hours # InactivityTimeout 5hours WebSocketsPing 30seconds </Route> <Route ^\/fileservice(\/.*)*$> AuthRealm "validusers@robapi.abb" AuthType digest AuthDigestQop auth SetHandler rapi_filehandler Methods set ALL </Route> <Route ^\/docs(\/.*)*$> AuthRealm "validusers@robapi.abb" AuthType digest AuthDigestQop auth AddHandler fileHandler Methods set GET </Route> <Route /> AuthRealm "validusers@robapi.abb" AuthType digest AuthDigestQop auth SetHandler rapi_handler Methods set ALL </Route>
