Reference surface tool
When creating "paths on curves" generated from surfaces with double curvature I need a "reference surface" to control the target orientations.
The problem is that the path travels over many different surfaces and it is only possible to select a sigle one in RS. I am now looking for a tool to merge/join surfaces or to create a "spline surface" on top of the original "patches" before importing to RS. Anybody got an idea of a cheap great easy tool? ..or could It be an other way around this?
/erik
Hi Erik,
If you not select a reference surface, RS will automatically use the surface there the target is created as reference surface.
ABB Robotics0 -
Hi Anders,
Ooh - So thats why I have so good results without a ref surf! I figured something fishy was going on. Thanks for the info!
I can now trust the results./erik
