positioner MTC
Hello.
Where can I find positioner MTC file and the key file?
MTC models can you find here:
http://www.abb.com/product/seitp327/1f60c696c882e7ddc1256f3a 00526165.aspx?country=US&tabKey=7
Use the same configuration as for a L-positioner (mediapools for L-positioners are installed with RobotStudio).Best regards,
ABB Robotics0 -
Dear Anders
Thank you for your response.
But is this right address?
I can't find any available site.
Please check the address.
Best regard
Yu
Hi Yu,
You are right, the address doesn't work anymore. Follow this steps instead to find the MTC files:
Go to www.abb.com and select ABB Product Guide. In the product guide, go to Robotics and select Application Equipment & Accessories. Then select Workpiece Positioners and Rotary units.
ABB Robotics0 -
Hello Anders,
Thanks to your answer, I could find the positioner's data.
But I have to ask you 1 more question.
Where is the key file to use the data
which name begins from "3HEA-024"?
BR
Yu
Hello Yu,
As I said above can you use the L-positioner configuration. To do that, select the additional key: C:Program FilesABB Industrial ITRobotics ITMediapool3HEA-000-00052.Single_IRBP_Lextkey.kxt.
You can also use the cfg-file that comes with the robot ware: C:Program FilesABB Industrial ITRobotics ITMediapoolRobotWare_5.07.1023utilityAdditionalAxisDM1 GeneralM7L1B1_DM1.cfg.
ABB Robotics0 -
Hi Anders
Thank you for your kind replies.
Yu
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 347 IRC5
- 74 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 109 Collaborative Robots
