excel data
Hello
Can we use excel file data or other data in RS?
We want to create targets from such data file.
Yu
Dear Yu,
Excel data cannot be used directly in RS. But, as a workaround, I would recommend you to create RAPID code from the data by some "Excel engineering", paste that code into a RAPID module, load the module in the VC, and sync to station.
Remember, though, that the robtargets must be referenced by a Move-instruction to be synchronized to the station.
Regards,
Henrik
Henrik Berlin2006-11-21 12:56:42Henrik Berlin
ABB0 -
Hi Yu,
Next release of RobotStudio (RS 5.08) will contain VSTA (Visual Studio Tools for Application). With VSTA will you be able to write your own macros. So then will it be possible to write a macro that for example import data from Excel, and creates targets from it. The program language in VSTA will be Visual Basic and C#.
ABB Robotics0 -
Hello Henrik and Anders
Thank you for your replies.
I'll do it if I can.
Yu
- 10.3K All Categories
- 5.2K RobotStudio
- 341 UpFeed
- 14 Tutorials
- 281 PowerPacs
- 404 RobotStudio S4
- 1.7K Developer Tools
- 236 ScreenMaker
- 2.6K Robot Controller
- 240 IRC5
- 34 OmniCore
- 3 RobotStudio AR Viewer
- 678 RAPID Programming
- 14 Wizard Easy Programming
- 100 Collaborative Robots
- 3 Job listings
