RobotStudio Manual Joint Fail
I'm having a serious fault while jogging robot manually with the mouse... I'm trying to rotate the TCP, and the robot... just goes crazy...
Please see the following video example...
https://youtu.be/viOVc4Uzgw0
Un saludokind regards,
Daniel Aguilar
Automation Engineering
  • Try using the jog linear (right click robot in the layout tree and select mechanism linear jog), and use the RX, Ry<RZ with the drop down set to your tool.
    Thanks for reply. I am currently testing on an IRB4600 and I found same problem. Checked the way you said, it works, but, this is a too slow way for the orientation of the TCP.
    This is a completely new BUG of RobotStudio.
    Daniel Aguilar
