Conveyors tracking with multimove option
pacijent
Hello to all. I was looking for description of multimove coordinated and independent RW option, and I could see that independent option does not support moving workobject. If I have two moving conveyors and two robots working independently, each on one conveyor, they are acting independently, I guess? We might have two flexpickers mounted next to each other following two moving conveyors, and packing fish into boxes placed on 4 static conveyors which shift full boxes. What would be the proper setup in this case, can we combine two conveyor tracking interfaces with multimove independent or coordinated RW option. Thanks a lot in advance.
P.S. Can they work on both conveyors at same time,and what would be setup then, and can I limit overlapping motion defining conveyor's connection. Integrator doesn't want PM3.
- 858 RAPID Programming
