Flexpendant error when use RW5.07.02
lumboon
My RS is working fine with RW5.07.01 but when I installed RW5.07.02 or up, the system created with later RW has error on Flexpendant, error message"Unhandled exception has occured in your application......class not registered".
Anyone faced same problem. Please suggest.
Lumboon S.
Robotics Division
ABB Limited
Hi Lumboon,
Have you also installed RobotStudio Online 5.07.02? If not, try that.
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0 -
Hi Johannes,
Thanks for suggestion. I installed RS Online 5.07.02 and Flexpendant error disappeared! It's worked now.
regards,
Lumboon
