RW 6 rpk file error when creating system
pacijent
Hello to all, when I'm trying to create system from layout I'm getting error: "Given productDistribution does not have any rpk files". I'm using RobotStudio 6.04.01, and this is happening with different versions of RobotWare. Please help.
Thanks.
Thanks.
Please go to %localappdata%\ABB Industrial IT\Robotics IT\RobotWare in your windows explorer and move the contents of RobotWare out of the RobotWare folder (for example 1 step up to %localappdata%\ABB Industrial IT\Robotics IT\) or to some other Backup folder.
Now try to create a system.
There is some bug in RS6.04 where certain custom packages inside the folder are causing problems. R&D is working to fix this problem./Adnan
