RobotStudio bug: Undo will not undo changes made to a targets reference frame
I noticed this behavior:
1) Create RobotStudio path
2) Use RobotStudio translate or rotate path functions
3) Undo Step 2 above
4) Notice the reference frame location is not undone.  It is still located where it was left in step 2
We've even tried our undo context, but it didn't change anything.
Any change a work item could be created to fix this undo issue?
