Error in automatic program checking
Crux
I'm facing a problem, I used sockets in other applications and this very same function worked without any issue;
is it possibly a Robotstudio bug ?
are system functions dependant on the controller used or are they universal for any controller able to use rapid?
(this is because the first time I used an irb140 and I had no problems, this time I'm using an irb120 and I got this error)
I suppose this as a robot studio bug since inside the IDE the function is correctly recognized, it is in light blue and with mouse hovering it displays the correct infos
Any idea how to solve it?
Do you have the option PC interface on the robot ?
Regards
Knud Erik Lindberg
Danrobotics1 -
Oh, it was easy like that, I enabled the option and it worked fine.
I would suggest to include this info in the error log, I did not know that this option was required, I did think that pc-interface was the option for enabling the service port and that the network port was always accessible even without service port enabled; my bad.
Thank you knud.0
- 40 AppStudio
