Robot Studio 6.04.01 Exception Error
Hello Everyone,
So I removed all of the old 5.61.04 information off of my work computer and installed the new 6,04.01 version from the website. Everytime I open the program and go into the RAPID tab the output window gives me this fault
RobotStudio license will expire in 15 days 3/15/2017 9:54:37 PM General
Exception: The type initializer for 'RobotStudio.Services.RobApi.RobNetscanCOM' threw an exception. 3/15/2017 9:54:40 PM General
RobAPI exception 3/15/2017 9:54:40 PM General
TaskException 3/15/2017 9:54:49 PM General
When I click on line 2 Exception... this is the output:
RobotStudio .NET exception: The type initializer for 'RobotStudio.Services.RobApi.RobNetscanCOM' threw an exception.
Base exception: TypeInitializationException
at RobotStudio.Services.RobApi.RobNetscanCOM.get_RobNetScan()
at RobotStudio.Services.RobApi.RobNetscanDesktop.GetAllNetscanIdsInternal()
at RobotStudio.Services.RobApi.RobNetscanDesktop.GetAllNetscanIds()
at RobotStudio.Services.RobApi.RobNetscanDesktop.GetAllControllerInfos()
at RobotStudio.Services.RobApi.RobNetscan.<>c__DisplayClass16_0.<GetAllControllersAsync>b__0()
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.Services.RobApi.Retained.RobRetainedNetscan.<Init>d__6.MoveNext()
Inner exception: COMException
Retrieving the COM class factory for component with CLSID {7475A420-6FEF-4034-B472-64B675B4F290} failed due to the following error: 8007041d The service did not respond to the start or control request in a timely fashion. (Exception from HRESULT: 0x8007041D).
at RobotStudio.Services.RobApi.RobNetscanCOM.Initialize()
at RobotStudio.Services.RobApi.RobNetscanCOM..cctor()
System
Dell Latitude E5570
Windows Pro 7
Intel Core i5-6300 CPU @ 2.40 GHz
8 GB Ram
64 bit Op system
Thank you in advance and please let me know if there is anything else that is needed from me for information.
The error window is somewhat misguiding, what in most cases is that the RobAPIService: 'ABB Insustrial Robot Discovery Server'
has been disabled or of some other reason will not start and communicate with RobotStudio.
To make sure the service isn't disabled please go to services by: start->type:services.msc
Then find 'ABB Insustrial Robot Discovery Server' rightclick -> properties and in the General tab click on the "Startup type" and chose Automatic.
Hopefully this helps!!
Best RegardsAdnan
1 -
Although my settings were set to manual this error still occurs.
In the services window if I try to manually start the ABB Industrial Robot Discovery Server with the 'Start" button, I get an Error 1053:The service did not respond to the start or control request in a timely fashion.
Adnan, thank you so much for the prompt response and for the help.
This is still occurring and I have had so many techs just send me the link for downloading the 6.04 from the site. I would appreciate any other help that I can get with this and thank you in advance.
It sounds like your service was built against 'Any CPU', causing you errors on 64-bit where you are using COM components. You need to build it for x860
- 38 AppStudio
