Inductive sensor in RobotStudio
Hello there,
I have two kinds of objects which have identical dimensions, but one type is metallic and the other is made of plastic.
How can I sense them in RobotStudio? I thought of a line sensor for one...but for the other?
Thanks,
Alex
  • Hello
    ObjectComarer can separate 2 objects with the same name and size but different color. You can try something as below picture. Depending on which object the lineSensor senses the LogicSRLatch will output high or low.
    /Pavel
